damn cast iron comeback!
发表于 2021-9-1 00:09:10 | 显示全部楼层 |阅读模式
Dude comes to shop asks to weld pot, gave him the "its cheaper to get new one" speech. He gave me the speech- "its my dead uncles pot he had for 30 years and it cracked the first time I used it". So I welded it, about 4 months later he comes back and told me that the pot leaks. It cracked along weld and into new area as you can see from gouge. I asked a few questions and if the answers were true it porbably would not have come back?Another day of having fun at the shop!Peter Attached Images
Reply:I forgot procedure! gouge, preheat 650, OA braze hot, post heat 650, turn off oven let cool.Peter
Reply:Whatever he's doing to that thing, he's gonna have it looking like a roadmap pretty soonI'll bet he boiled it dry, or something like that."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammWhatever he's doing to that thing, he's gonna have it looking like a roadmap pretty soonI'll bet he boiled it dry, or something like that.
Reply:Why did you braze it instead of OA spray or OA welding with cast iron rods?  Ductility?Have we all gone mad?
Reply:So why not the iron powder spray weld process on the pot?  Wrong material?  Just asking because I don't have a clue.oops.  sn0border88 beat me to it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice old school repair! Ever try tiggin with bare brass. works excellant.Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:Originally Posted by sn0border88Why did you braze it instead of OA spray or OA welding with cast iron rods?  Ductility?
Reply:Originally Posted by gclampNice old school repair! Ever try tiggin with bare brass. works excellant.
Reply:it will keep cracking no matter what is done to it.been through this with lodge cookwareinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Originally Posted by castweldOnly because its cheaper process.No to cast rods beacuse it would have required 1100 degree heat and much longer cool down.Once pot is re-seasoned the crack is barely visible.Peter
Reply:Originally Posted by gclampLet me re phrase my post. Nice repair, That is old school knowledge of a craftsman. should have been separate post on tiggin with brass. didn't mean to apply it to that job. sorry. . sorry for the mis understanding
Reply:If it comes back the third time I'd tell him it needs to be put on a shelf or plant flowers in it. It's looking like a dead horse to me.                                       MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by chenryit will keep cracking no matter what is done to it.been through this with lodge cookware
Reply:Originally Posted by hillcoDitto!  There are jobs you should turn away, or only do with the clear understanding that you are "sticking it back together", but it is no longer fit for service.  I run into a number of these with cast iron and old rusted out lawn furniture that the ladies want to use only for decor or to place potted plants on.  I say it before I take the job, and repeat it when its finished...doesn't mean it won't come back, but I won't feel bad charging them again, and giving them the talk all over again.  Too bad I can't tack a little microchip on the piece confirming the confirmation on a certain date.
GMT+8, 2025-12-25 09:15 , Processed in 0.089812 second(s), 18 queries .
