Stairs and Rails
发表于 2021-9-1 00:09:09 | 显示全部楼层 |阅读模式
Just some regular old stringersThis is the printSitting on the horsesTriple 7 I love itDrillin holesDone for todaynext postDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:These mount to the stringersHere is what we are making them from, 1.5" Sched 80 6061 aluminumThe saw The coping machine Angry Vinnie  with the first railing that took all dayNextLast edited by TozziWelding; 05-30-2009 at 12:42 PM.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:The stringers and rails  are back from the galvanizer, and ready for a dry run in the shop before they get installed. Everything fell together, I only hope the next set goes this well. Enjoy.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Very nice?  What did you use to weld the rails?   Oh, I guess tig.   I finished four sets for a chemical plant a few months ago.  Those guys had been climbing ladders for 30 yrs.  Multiple trip, daily up 9 foot ladders to feed and moniter hoppers.
Reply:a$$hole welder my  a$$.Wish I could do that.A butterfly without wings, is just an ugly bug
Reply:man i dont miss stringers! we used to use a lot of the "jr. channel" to build ours. 12" wide a pounds per foot maybe? i always wondered why we didnt just go with a more heavy duty channel cuz they would warm so bad and we would have to heat straighten them. ill throw a few pics up of the warpage. if we would have welded them like you did the angles we would have had a BUNCH of heating to do. This one was like 3" out. Attached Images
Reply:i take that back, i do miss doing stringers lol
Reply:Originally Posted by Magnetic Mechanica$$hole welder my  a$$.Wish I could do that.
Reply:Another neat one, thanks for the pics!!!!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:great job and nice shop
Reply:Very nice. Dry runs a great Idea, too. It can save a lot of time/money/embarrassment. I like to do that on any job that gets galvanized or powder coated. Was the sch 80 spec'd by engineer/architect/end user? Reason I ask is (unless I'm mistaken) sch 40 will pass most codes.I thought all welders were a$$hole welders, I know I am.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:I used to do a lot using 12" junior channell that would warp like El_Lloydeo  said. If we were lucky the mate to would be built at the same time and we'd tack them back to back bent the opposite way before welding.......Mike
Reply:Originally Posted by mrmikeyI used to do a lot using 12" junior channell that would warp like El_Lloydeo  said. If we were lucky the mate to would be built at the same time and we'd tack them back to back bent the opposite way before welding.......Mike
Reply:Not very often, if we did it was just on the ends and usually a well placed belt with a bfh on the edge of the flange (suitably protected with a piece of scrap) would do it.We didn't weld our clips all around neither, just on each end 'bout and inch or so wrapped around the actual end of the angle and one in the middle. The hardest to keep straight was the crank as there's more weld on the longer length of angle and there usually wasn't a mate to it as the ones with cranks were all the same way...Mike
Reply:Man oh man that's some nice work you've done there. I wouldn't know where to even start something like that. Congrats. Miller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Originally Posted by app-ironworksllcVery nice. Dry runs a great Idea, too. It can save a lot of time/money/embarrassment. I like to do that on any job that gets galvanized or powder coated. Was the sch 80 spec'd by engineer/architect/end user? Reason I ask is (unless I'm mistaken) sch 40 will pass most codes.I thought all welders were a$$hole welders, I know I am.
Reply:This is the set we just finished as a fire escape, color galvanized.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingSched 80 is what was speced, we welded all around because that was speced for the galvy. I installed them this week they fell in and all the pans fit
Reply:color galvanized ??insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Yup, http://www.duncangalvanizing.com/colorgalv/Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Do they give the piping a good looking over for burring and snags when it gets inspected
GMT+8, 2025-12-25 09:23 , Processed in 0.098271 second(s), 18 queries .
