SMAW electrode and parameters selection
发表于 2021-9-1 00:09:06 | 显示全部楼层 |阅读模式
Hi, I need to define parameters for a SMAW welding process for doing a fillet T-weld.  One of the metals has a thickness of 12.7 mm (1/2") and the other one 1/8".  The base metal is a ferritic stainless steel (AISI 429).Does anybody have any reference that I can use to select the electrode,diameter, current and voltage?  Preferrably an online reference, I don't have much access to books.Thank you.
Reply:Lincoln procedure handbook for arcwelding.  Available at Lincoln.com.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I am assuming that you are doing work for school???  The book David mentioned is a good one for that info, but I will add if you ask for parameters on here for a given joint you will get numerous answers.  Every weldor here welds different and uses variations in the chosen parameters, but the end result will be the same.  A quality weld.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Ok, thank you.  I'll try to get the Lincoln handbook.
GMT+8, 2025-12-25 09:23 , Processed in 0.067138 second(s), 18 queries .
