Jackson Hellraiser Nexgen Helmet
发表于 2021-9-1 00:08:55 | 显示全部楼层 |阅读模式
I picked up this helmet today for $60 when I went to get a Miller plasma cutter.  There is no response when the on/off button is pressed.  I'm assuming it needs batteries as the helmet appears barely used.  The plasma cutter was used only twice and is in perfect condition.  Is there a manual available online for this helmet?  I need some help understanding the functions of the helmet and how to go about changing the batteries.  Thanks.  Btw, got a Miller Spectrum 375 (not extreme) with a cart, cover and owners manual for $575.  I thought it was a good deal.  It doesn't have a drop of wear on it.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:I don't know anything about the helmet, but that is a very good deal on that Miller 375, almost a steal. I have the old 300, nice machine for it's size.Welder- Miller Thunderbolt AC 225-DC 150 Plasma cutter, Miller Spectrum 300O/P torch- Victor 100
Reply:Bump.  Anyone?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:I don't have one, but there should be 2 compartments that pull out.Do you not see them??>>Replaceable lithium batteries (included) with low battery indicatorDoors look like....this and should slide out..Last edited by skelley521; 09-27-2011 at 04:25 PM.Semper FiJesus may have been a Carpenter, but his dad was a Millwright" A grinder and a can of paint, will make a welder what he aint' "I've done so much, with so little, for so long, that now I can do anything with nothing!
GMT+8, 2025-12-25 09:15 , Processed in 0.104832 second(s), 18 queries .
