Primer
发表于 2021-9-1 00:08:54 | 显示全部楼层 |阅读模式
I know it's not a project or a picture, but it has to do with the projects. When I work on something, after I run and dress a bead, and after it cools, I try to give it a shot of primer as soon as I can.  And I got to thinking about all the different types of primer.  I've used Krylon, Rustoleum.  They have been greym, black, rust, sandable, self etching and so on.  What do you guys use and more important WHY?
Reply:Originally Posted by JC'sWeldingI know it's not a project or a picture, but it has to do with the projects. When I work on something, after I run and dress a bead, and after it cools, I try to give it a shot of primer as soon as I can.  And I got to thinking about all the different types of primer.  I've used Krylon, Rustoleum.  They have been greym, black, rust, sandable, self etching and so on.  What do you guys use and more important WHY?
Reply:I don"t paint.  Just usually prime and deliver.
Reply:I  prime with what ever is on hand . I like to spray it when the welds still warm to give the bake on ,       I don't know if this helps ,but I think it's cool.Daye
Reply:Well, I blast it and prime with Intergard 343.
Reply:red rusty metal primer works the best as far as I have seen
Reply:for small touch ups nothing beats the cheepest walmart red oixide rattle bomb you can get.   I have to get them 4 counties away from here and get them every chance i have.    Other big jobs get triangle triprime.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:What is Rustoleum?I just use red primer applied as soon after I weld as practical. Then I top coat x 2 ASAP, too. Having said that, I naturally have things around the place that never get past primer.
Reply:Originally Posted by scott brunsdonWhat is Rustoleum?
GMT+8, 2025-12-25 09:17 , Processed in 0.093415 second(s), 18 queries .
