Forked trailer bed
发表于 2021-9-1 00:08:52 | 显示全部楼层 |阅读模式
Someone needs to slow down and aim a little better.. This customers bed was forked pretty bad, so I notched out the piece and put a new piece of angle in it's place.  I cut the hole first and then matched the angle to it.. it's alot easier that way. Unfortunately,  there was a bit of a gap between the new and old, but I managed to fill it in without too much trouble.  I ran really hot with lots of dig so I could make a full pen weld so when I ground the weld off, there wouldnt be any issues.The job took about 30 minutes. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Nice save brainfarth.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-25 09:17 , Processed in 0.095269 second(s), 18 queries .
