thermoelectric-coolers
发表于 2021-9-1 00:08:41 | 显示全部楼层 |阅读模式
http://www.directindustry.com/prod/e...31-566716.htmlany ideas what we can use them for maybe put one on a welder ?Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:It usually comes down to is the equipment box presently being used big enough and enough spare room to put one in. If not then some type of ductwork is used to do it, or a change out is done to a bigger enclosure.My computer can probably do it as it is a custom built with room provided. But do you need it???? There can be condensation issues if it over cools. How to control the beast?For most things it is keep it clean, dust build up and junk is the biggest problem inside the machine or blocked / impaired air flow . Probably applies to welders as well. Most machines are probably Ok with just the factory set up, unless you are pushing it extra hard. About the same as most computers or whatever. Maybe nice to have but not super needed for normal use.
Reply:no not needed but i was thinking as an added piece to a tig cooler drop the water tem farther as it cycles from gun to tig cooler and reservoir tank loli just think they are neatLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:you could put a copper tube coil between the tank and torch then have the little ac on the coil :]
Reply:there we go some thing like that justinLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2025-12-23 13:13 , Processed in 0.090822 second(s), 18 queries .
