I want a new 110 vac machine.. any suggestions?
发表于 2021-9-1 00:08:40 | 显示全部楼层 |阅读模式
Im lookin for a new 110 vac machine.Ive used them before and enjoyed welding with them. Just wanted to see if you all had any suggestions. weld it like you own it
Reply:Stick, mig, tig?Guess the next question is what you want to do with it?For Mig I'd vote for something like the MM211 or the newer Hobart multi voltage machine as opposed to a strictly 110v mig.  The Passport Plus would get you the most power of all the small migs on 110v, but it's quite pricy. It would be my choice for a portable 110v mig with some balls.. There not much else new that I'm aware of in the 140 amp class migs, so if you must go with one of them, then the MM140 or Hobarts or Lincolns equivilent.Stick and tig would go together somewhat. The TA95S if it had to be 110v only.  The Maxstar 150 or better yet Maxstar 200 if you wanted a stick or DC tig that's got the most available on 110v power. and could run 110v/220v. The Dynasty 200 if you wanted an Ac capable tig or needed to run 6010 stick on 110v power..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I use the heck out of my Hobart HandlerTim Beeker.
Reply:I wouldn't buy a new one, I'd buy a tried and true older model. Same output, just lower price (although, like any used vehicle, you may have to do some "refurbishing", depending).XMT304 (school)SP125+ (home)HF 4x6 BandsawGood judgement comes from experience and much of that comes from bad judgement.
Reply:In addition to which welding you want to use, tell us if you have a budget limit.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:For a little machine, for $600 and change, you can't beat a MM140 w/ auto set. I do like the dual voltage input machines though.
Reply:my brother bought a lincoln 140c for $600, it does pretty good, but its still limited with the 110v input.. i'm with DSW, if i were to buy a 110v machine i would go with the hobart 210mvp, lincoln 180 dual they are 110v-220v so you have room to grow..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2025-12-23 13:14 , Processed in 0.092927 second(s), 18 queries .
