Looking for welding repair in NYC
发表于 2021-9-1 00:08:40 | 显示全部楼层 |阅读模式
I'm looking for someone to repair a weld on a double stroller in Manhattan.It's a phill and teds double stroller with a steel frame. One of the welds has broken and the frame is about to fall apart. I'm sure its a fairly straighforward fix, but I don't know where to find someone in Manhattan who could do it. I came across this forum through a google search, so I thought I'd ask.Thanks
Reply:how old is the stroller? and what happened that one of the welds broke..best bet would call manufacture and complain. thats something that shouldnt happen. its also one of those cases that the last person touching it will be liable for any injuries that happen if it comes apart even at another weld...just a thought..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:.. ro-76, you may want to do a search for RECALLS on Phil & Teds stroller/s (44,000 of themthere IS a Recall for some strollers:;  due to AMPUTATION RISK!!!! before any repair is done i strongly suggest  do more research if any repair is attempted this WILL void any recall action in your favoridealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:here is a number to call to check to see is yours was a recall...1-855-652-9019idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:May I ask the purchase price of said stroller?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-23 13:13 , Processed in 0.205377 second(s), 18 queries .
