Large weldment trunnions (rotisserie)
发表于 2021-9-1 00:08:35 | 显示全部楼层 |阅读模式
Whipped these up for a job yesturday. We are trying to get the higher ups to let us build a powered version similar to this. Attached ImagesDarwinian evolution used to fix stupid. Now that humans have mostly removed themselves from the process of natural selection the survival rate of idiots has skyrocketed.
Reply:I like the hinged piviots. Lot nicer than moving the end to slide out the holder.
Reply:Now you need to build a 12' grille underneath, and ..... What is that particular rotisserie used for?  Auto shop?
Reply:would be good to make a bracket up to clamp ladders to them to make welding alot easier, these could be used for so many things
Reply:What are you going to use it for?  Looks nice
Reply:Now that's pretty nice. The triangular base is a nice tweek you don't see on most rotisseries.
Reply:By the looks of the plate and shapes, it's gonna have some serious weight on it with little deflection allowed."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-23 13:11 , Processed in 0.129307 second(s), 18 queries .
