Converting tube bender from manual to air/hydraulic, this frame stong enough?
发表于 2021-9-1 00:08:34 | 显示全部楼层 |阅读模式
Hi all,I've had my JD2 Model 3 for a year or so now and finally have a little time to get the cage on my CJ-7 built.  I'm using 1 3/4" .120 wall HREW for the cage.I've found lately that converting these to work with a cheap Harbor Freight air/hydraulic cylinder is just as simple as making the frame to hold it, the cylinder itself was only $80 on sale.My plan is to build the frame for this bender out of scrap channel iron I have, not ideal but the price is right.  I was wondering if you guys could take a look and see if it's strong enough as is, or if I need to add more bracing;Mocking it up with a manual cylinder (hadn't got the air/hydro yet at the time);Welded with some triangulation;Strong enough you think or should I add some more, like maybe this;Thanks,Jordan
Reply:add that extra piece or it will bend. cheapest way ive seen to convert it, good jobLast edited by beamed94OneFiddY; 06-18-2009 at 02:10 AM.lincoln weld pac 100Hobart handler 120Lincoln  "BuZZ box"Lincoln Precision Tig 225
Reply:Your going to need a strap from the bending arms back to the base, parallel to the 'C' channel.  If you don't put that in there, the hydraulic ram will want to twist the 'C' channel.1/4" x 3" strap should work.  Just bolt it in where the front bolts are & bolt to the hydraulic base.  Also add the second 'triangulation' at the base.  It will go a long way toward strengthening the base.  Looks good otherwise.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I ended up just bolting it to my welding table for the time being instead of messing with putting it on an old engine stand. I wanted to get to bending. It works excellent, only thing I do want to do is change the bolt in the bender where the ram attaches to a grade 8, but the grade 5 didn't have any trouble.  This cylinder works great.Jordan
GMT+8, 2025-12-23 13:11 , Processed in 0.085806 second(s), 18 queries .
