chicken cooking
发表于 2021-9-1 00:08:34 | 显示全部楼层 |阅读模式
hey guys i need to build some of the flipable chicken bbq racks.  anybody got a pic of how the hinges are done on these?   or a pic in generalwww.burdettenetworks.com
Reply:It's BEEF ONLY here.  I didn't know ya could eat a chicken"Any day above ground is a good day"http://www.farmersamm.com/
Reply:come on now same chicken is the fruit of the sea.... or is that tuna...  ah hell dont matter i still have to make this thing so i will just go at itwww.burdettenetworks.com
Reply:same = samwww.burdettenetworks.com
Reply:Samm,What else do you do with one?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Hey samm!You gotta admit, steak and "eggs" go awful good together with coffee in the morning!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:This is going to be hard to explain, but let me try......  Imagine if you had a grill where the grates were inged at the back, so you could open it, through the meat on, then close it, like a fish griller.  Then, at the back, take a 2 inch long rod, say 3/4" or 1" and weld it to the center.  That "rod" can travel up and down a slot in the back.  Whn you are ready to flip, you would have to lift the whole thing up, then rotate it, then drop it back down to the fire.  Make sense?
Reply:I'm picturing a seperate rack not part of the grill. About like the shrimp racks that you flip over. Those just use loops of wire or rings at the back.
Reply:Kinda like a burger rack, where you sandwich the patty in between two grilles, then flip as needed.
Reply:Originally Posted by kburdhey guys i need to build some of the flipable chicken bbq racks.  anybody got a pic of how the hinges are done on these?   or a pic in general
Reply:I built one a while back for a guy. Like Sandy said, rings work well for hinges. You want a bit of slop in it, since both side will be 2 - 3 " apart holding the birds. You can put 1/2 round on both ends long enough to sit on both edges of the grill. Then when you flip 'em, you have to slide the bottom over, and you almost need 2 people. The one I built was for a cinder block pit. He wanted the pivot in the middle, so he didn't have to lift all that weight (about 30 chicken halves).  Don't put it exactly in the middle though. It needs to be a little heavier on one side of the pivot point."We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
GMT+8, 2025-12-23 13:15 , Processed in 0.132926 second(s), 19 queries .
