Mig welds
发表于 2021-9-1 00:08:31 | 显示全部楼层 |阅读模式
This is a trailer the customer is beefing up.  Top piece is 2 x 2 square tubing 24 feet 3/16 wall. Bottom is 2X4 3/16 wall.  Trailer frame is something thinner.  The top piece was tacked in place when I arrived the first day.  Both sides are welded front to back.  It took a day to do the top piece (100').  Tomorrow morning I go finish up and put the axles in.It won't let me put the pics up.  It was a Snap on welder, .035 wire on 5.5 and voltage tap on six what ever that all means.  C/25 gas.  I used a wire wheel to take off the surface rust in the groove  before I welded.David Attached ImagesLast edited by David R; 07-30-2007 at 04:08 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:You get all the fun jobs.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-23 13:09 , Processed in 0.116887 second(s), 18 queries .
