gas lens
发表于 2021-9-1 00:08:30 | 显示全部楼层 |阅读模式
What is the differance in the cheap gas lens and the higher price gas lens and is it enough to make a differance in the weld.  Never used a gas lens before so this is new territory to me, any advice is greatly appreciated
Reply:Originally Posted by tensefanWhat is the differance in the cheap gas lens and the higher price gas lens and is it enough to make a differance in the weld.  Never used a gas lens before so this is new territory to me, any advice is greatly appreciated
Reply:Sorry, i was talking about the filter lens. see learned something new already. Any differance in ceramic lens and lava lens, All i've every used is ceramic and hate to pay the high price for lava and it not be any betterLast edited by tensefan; 08-02-2007 at 09:20 PM.
Reply:Originally Posted by tensefanSorry, i was talking about the filter lens. see learned something new already. Any differance in ceramic lens and lava lens, All i've every used is ceramic and hate to pay the high price for lava and it not be any better
Reply:I can't think of anything my cheapie gas lens wasn't able to do, so I can't see any justification on a higher priced version.
Reply:the pink (alumina) or gray (lava) part is the nozzle.the brass part is the gas lens, ain't no such thing as a 'filter lens'.lava nozzles are for high heat applications.tungestion must be what happens if you eat too many EWTh2%'s.
Reply:Originally Posted by ChamferTrodethe pink (alumina) or gray (lava) part is the nozzle.the brass part is the gas lens, ain't no such thing as a 'filter lens'.lava nozzles are for high heat applications.tungestion must be what happens if you eat too many EWTh2%'s.
Reply:The alumina lenses are injection molded and mass produced.  The lava lenses are machined on a lathe, so they're more expensive.Here's a little primer on nozzles and collets and gas lenses...http://www.thefabricator.com/ArcWeld...le.cfm?ID=1446In the case of gas lenses, I have seen some cheaper ones that don't offer the same coherent gas flow due to the fact that the screens inside aren't spaced properly.  I've also seen ones that haven't been brazed and in fact fall apart.-----------------------Carmen Electrodewww.CarmenElectrode.comand the boss blogs at  www.JoeWelder.comall powered by  www.Arc-Zone.com
GMT+8, 2025-12-23 13:11 , Processed in 0.100193 second(s), 18 queries .
