Material identification-picnic folding chair
发表于 2021-9-1 00:08:25 | 显示全部楼层 |阅读模式
Does anyone know the material of the tubing made for these folding chairs?I thought they were aluminum but it stuck to a piece of magnet. I was planning on cannibalizing some chairs and use the tubing for project. Has anyone successfully welded these tubing?Thank you
Reply:if a magnet stuck to it then it will steel or a type of ferrous metal containing ironmore than likely steel tubing ( TIN ) cheapidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Hey qdn,Always check unknown material with a magnet as that will answer a lot of questions. I have repaired both steel & aluminum tubing chairs like that & have used that material for projects. Since it is thin, your best results will be to use a plug on the inside, a collar on the outside, or both if the strength is needed...... you know there are some fairly large butts that tend to exceed designs of weight & material stress. It is not hard to repair if you use the correct approach.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Steel. Aluminum that was that diameter would not be able to support the weight unless it had very thick walls and was well designed. Plus the magnet sticking to it is just another sanity check
Reply:Thank you everyone for your response.
GMT+8, 2025-12-25 09:17 , Processed in 0.069465 second(s), 18 queries .
