Watch this
发表于 2021-9-1 00:08:24 | 显示全部楼层 |阅读模式
Not completely sure that the side swipe helped it along but at 0:50 it happens and at 3:20 it looks like it was the result of insufficient weld reinforcement to compensate for the stress placed on the rear end.http://izismile.com/2011/10/05/drag_racing_fail.htmlWelding Supervisor Department of Corrections.
Reply:never re-use shackle bolts..Buy American, or don't whine when you end up on the bread line.
Reply:454 posts, Vroom Vroom!Buy American, or don't whine when you end up on the bread line.
Reply:should have been reinspected before running againidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:. . . but the guy at the counter said that 120V, 90A MIG welder would do the job . . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Awesome Video!The first two runs, I thought... what the 'h', nothing much here, then came the third run - Whoppee!I don't see how the side swipe in video 2 could have influenced the rear end to that extent.Guess you got to beef it up some... thanks for sharing this.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Number 1, hit the wall and kept on driving.  Just stupid.Number 2, the axle litterally ripped out of the ladder bar mounts.    Its possible this happened because he had too much pre-load.  That car did launch awful - ladder bars like launching flat flat flat.  But he should have bend the ladder bars long before the mounts ripped off the housing.  That was too clean of a break.  I vote substandard welding.   I'm pretty sure companies like Currie offer .250 wall tubing in their axles.  That's not going to get welded with a 110V welder.Also the side hit might have tweaked the Panhard bar.  Shouldn't have done much to the ladder bar.Lets put it this way, plenty of cars making a lot more power than that one never see suspension failure for lifetime of the car/chassis.  I'm guessing this one probably an early run, like run No. 2 for him.Thankfully he learned the good (but hard) way - he survived.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:If the welds boxing in the 4-link axle mount are any indication of the mount to axle welds it is no surprise.I like how they act like they accomplished something when they get out of the car. The guy with the red camaro did the same thing when his rear end left his car.Last edited by VPT; 10-06-2011 at 09:03 AM.
Reply:Hey welding machine, there ain't a shackle bolt on that car. It was a four bar and the welds holding the bat wings onto the axle broke off. They likely didn't use enough amps on it when welding. Those rear axle tubes are thick steel, and take a lot of heat!
Reply:I think  they used the wrong glue when they put it together.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:Can't be much of a Sanctioning Body at that track....When the driver is done acknowledging the crowd, and steps clear of his car he is wearing SHORTS... The Firesuit Jacket is kind of redundant after seeing that.Good to see that the driver's prosthetic left leg isn't keeping him from doing something he appears to enjoy.Crappy Welding = Bad things happening.Later,Jason
GMT+8, 2025-12-25 13:18 , Processed in 0.203256 second(s), 18 queries .
