cut 1 inch steel plate
发表于 2021-9-1 00:08:20 | 显示全部楼层 |阅读模式
Used PC precision cutting and grinding equipment.PC= Peter Controlled (me)Fellow came to my shop wanting bid on spacers. Needed to space armrests on weeel chair outward 2 inches to fit his father, he is rather large. He has not been able to transport his dad to DR because of this.Oxy 40 psi, acet 10 psi, Victor w/#4 tipI have not cut 1 inch plate lately so be gentle!Drilled holes in Bridgeport.Did not charge for plate or labor. Got that "good deed of the day feeling".Peter Attached Images
Reply:Nice work, and nice, looking-out for your neighbor. Last edited by denrep; 06-24-2009 at 11:29 PM.
Reply:Originally Posted by denrepNice work, and nice, looking-out for your neighbor.
Reply:That's something elseHardest thing to do is to have the patience to let the torch do the work when cutting that thick.  Too fast, and you got a mess.  Too slow, and you got a filled in mess"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Ha, bet he was a little surprised !!  Great deal, great work.
Reply:Originally Posted by farmersammThat's something elseHardest thing to do is to have the patience to let the torch do the work when cutting that thick.  Too fast, and you got a mess.  Too slow, and you got a filled in mess
Reply:Sandy, I get real nervous when it's that thick.  It's really easy to mess it up.That's some real nice stuff.Tip size is pretty important, and 02 is pretty important pressure wise.For someone like me that doesn't do this on a daily basis, it's pucker timeI'm pretty sure that most would agree."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Like previously stated, good looking out for the guyhaven't had the opportunity to use an OA, we only have a plasma here.  Would like to try someday thoughMechanical Engineer
Reply:Karma comes to mind here.  9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Good deed, dude.
Reply:nice work, nice guy
Reply:Nice pay it forward!“Life is not a journey to the grave with intentions of arriving safely in a pretty well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming ... WOW! What a ride!”
Reply:Originally Posted by BLUE2KSSLike previously stated, good looking out for the guyhaven't had the opportunity to use an OA, we only have a plasma here.  Would like to try someday though
Reply:Originally Posted by SandyI just did some 3/4 to 1&1/4 inch railrod iron the other day. I would have taken pics but would have had to put them in a "massacre" thread.
GMT+8, 2025-12-25 09:17 , Processed in 0.093207 second(s), 18 queries .
