RV repair
发表于 2021-9-1 00:08:16 | 显示全部楼层 |阅读模式
here's a little rv repair I did the other day,  The guy hit the camper with a bobcat . nothing better than alum. diamond plate band-aid.daye Attached Images
Reply:did you do both sides to balance out the look? COOL repair.Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:ooh, i like that look better than the factory seamI break things for a living...
Reply:yep, I did one on side .daye
Reply:That's pretty neat!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:part on driveway is left side fabricated piece, other pic is right side mounted on trailer"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammpart on driveway is left side fabricated piece, other pic is right side mounted on trailer
GMT+8, 2025-12-25 09:17 , Processed in 0.092227 second(s), 18 queries .
