Welding brass to 304 Stainless Steel
发表于 2021-9-1 00:08:14 | 显示全部楼层 |阅读模式
Hello.   Quick question.  I am wondering if there are any issues of welding a brass hinge (about 1/8" thick) to 14 gauge thick 304 stainless steel sheet?Len
Reply:I've welded both...But not to each other...Try 309 for filler..Maybe try brazing it instead????...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Assuming this is not intended for much structural strength anyway, I might also try Silicon Bronze filler.
Reply:Stainless hinges can be had in all shapes and sizes from any door hardware supplier. That would uncomplicate things. You only need to be 2% smarter than what you are working on.Lincoln pm140hacksawa big hammer
Reply:Originally Posted by MAC702Assuming this is not intended for much structural strength anyway, I might also try Silicon Bronze filler.
Reply:Braze welding  ? I was taught in my (welding) apprenticeship that brazing is NOT welding, it is "Hard Soldiering", unless it's brass to  brass[SIZE="5"Yardbird"
Reply:That's why Spanish is so much easier.  Soldering, Brazing, and Welding are all the same verb: "soldar"Or does that make it more confusing?
Reply:Originally Posted by MAC702That's why Spanish is so much easier.  Soldering, Brazing, and Welding are all the same verb: "soldar"Or does that make it more confusing?
Reply:Originally Posted by SandyNope, the spanish language can be pleasant that way. Many things just don't matter till they matter, then more explanation suffices.
Reply:Braze it.Or get stainless hardware to go with the stainless, and then weld it or braze it together.
Reply:or you can always get some grade 5 bolts...My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:For shame Elvergon! This is the WELDING forum, not the Bolting forum! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:How about just using JB WELD, its at least got welding in the name, if i was to want to make a brass hinge mate to stainless, I too think i would just bolt or rivet it, but I would perfer to just buy stainless hinge and weld it, this way things match up and look pretty.
Reply:Originally Posted by MicroZoneFor shame Elvergon! This is the WELDING forum, not the Bolting forum!
Reply:Originally Posted by Roy HodgesBraze welding  ? I was taught in my (welding) apprenticeship that brazing is NOT welding, it is "Hard Soldiering", unless it's brass to  brass
Reply:Silver based brazing alloys work very well for joining dissimilar metals and wet out on stainless steels well.  Harris SaftySilv 45 or 50N will work perfectly for this application and will make a joint that is very strong.
Reply:Stainless can be very difficult to braze, it is often done in a vaccum chamber. Heat is important.... that is not to over heat the material._________________Chris
Reply:A couple fellows I know that weld for a boiler company tell me the OXY Acetylene welding is just brazing. They just ignore me when I tell them they are wrong.Don't talk about it, Just do it!
Reply:Originally Posted by VicoorA couple fellows I know that weld for a boiler company tell me the OXY Acetylene welding is just brazing. They just ignore me when I tell them they are wrong.
GMT+8, 2025-12-25 09:16 , Processed in 0.088297 second(s), 18 queries .
