What I learned today
发表于 2021-9-1 00:08:11 | 显示全部楼层 |阅读模式
1) Mig welding isn't stick welding.2) Don't move the distance of your tip to "keep the wire in the puddle" it's not like a stick where the electrode changes length as you go. - It was funny my arm kept pulling back as the wire fed...3) Just because there is a setting for it in the cover, doesn't mean it's a good idea. .035 core on 18ga. - I did get it to run a clean bead - out of shear will and some fiddling with the settings.4) Tacking up the holes you make is only slightly easier with wire feed, and only because the arc strikes itself.5) I've never had a stick spring half its length at me in a violent attack. Stupid freeking wire on a spool, getting it loaded into the welder, It attacked me I swear!6) Hitting the sweat spot on wire is no less satisfying then stick.7) It's amazing how Stick AC / DC+ / DC- / and core all have a different look and sound. I can't wait to hook the gas up and try that!
Reply:Oh, so you got a chance to undo your first birds nest. If you're liking it so far you'll love solid wire with gas.
Reply:Try dropping a 60lb coil of wire and having it burst apart on impact...that will make your day fun!  Just wait until you try TIG.  Stick welding and Mig welding are not TIG welding...lol
Reply:I won't bother with TIG. It's only good for bonding razor blades. :P
Reply:Hey razor bonding is big business and just coming into its own!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by shaltacI won't bother with TIG. It's only good for bonding razor blades. :P
GMT+8, 2025-12-25 09:15 , Processed in 0.172934 second(s), 18 queries .
