Gas mixes for my MIG welder
发表于 2021-9-1 00:08:10 | 显示全部楼层 |阅读模式
I'm certain this has been asked a million times and if someone wants to just point me at the thread, off I'll go  Did a search and came up with lots of stuff that didn't answer my question and ran thru several pages of old threads.So..got the Lincoln Pro-Mig 175 and am planning to use it to: Learn to weld using various square tube and plates that I have lying around (up to 1/4" but mostly 1/8 and 3/16)Weld shock supports on my Jeep axle housing and also some solid round stock into bolt holes in my frame.And the first and foremost rookie project...build the cart for the welder to sit on.For general use and all around the house welding, do I want to use an 80/20 mix or a 75/25 mix?Thanks in advance!Roger
Reply:I would recommend using a 75/25 mix.It can also be called, C-25, SteelMix, Gold Gas, etc. It depends on the supplier.For me, 75/25 provides the best all around results for penetration and splatter control.If you are going to be burning a lot of the thicker materials (like 1/4" and up) , you might want to have a 2nd bottle with just CO2 in it. That will give you better penetration.Hope that's what you were looking for.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:Paul,That was precisely what I was looking for   and saved me hours of looking thru posts and interpreting comments.Thanks much..Roger
Reply:Heres shock mounts done with 92/8 GAS  multipass overhead ..not the best but it turned out good...ran out of 75/25                                                         I would not worry too much about it....but yeah go for the 75/25Last edited by lewray; 08-11-2007 at 11:59 AM. weld it like you own it
GMT+8, 2025-12-25 11:12 , Processed in 0.094275 second(s), 18 queries .
