Flux core nozzle
发表于 2021-9-1 00:08:04 | 显示全部楼层 |阅读模式
I bought the 226190 flux core nozzles for my MM175, but the tips stick out about 3/8" from the end of the nozzle? Every other welder I've had that used flux had the tip recessed. the part number matches my rig and the tips are normal size... what's the deal here?
Reply:won't hurt nothing..  all ya want is to cover the gas ports in the defuseridealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:I'm pretty sure it has something to do with protecting the tip from slag and spatter clogging. If it only protected the diffuser then non gas equipped migs wouldn't need a nozzle
Reply:Hello . classic ,  Prop-Doc is correct - you can run flux core without a nozzle if you have a screw on tip. The nozzle is only used for diffuser protection , it also gives you great view while welding without a nozzle , we go without one especially in tight areas.For our Bernard guns i have a nozzle cut down to the threaded area so it will hold in the tip and then i run a tapered tip , this suitcase stays on the service truck and gets a lot of use.
Reply:I haven't used the welder with this nozzle yet. I have had a bad slag and spatter problem using the mig tip. Should the problem be remedied with this tip? And if not what else could be doing it? I'm no pro but I've welded long enough to know my technique is good.
Reply:Originally Posted by Swamp ratHello . classic ,  Prop-Doc is correct - you can run flux core without a nozzle if you have a screw on tip. The nozzle is only used for diffuser protection , it also gives you great view while welding without a nozzle , we go without one especially in tight areas.For our Bernard guns i have a nozzle cut down to the threaded area so it will hold in the tip and then i run a tapered tip , this suitcase stays on the service truck and gets a lot of use.
GMT+8, 2025-12-25 09:18 , Processed in 0.091405 second(s), 18 queries .
