home made press about 2200 ton
发表于 2021-9-1 00:08:01 | 显示全部楼层 |阅读模式
adout $450 in hyd adout $300 in steel Attached Images
Reply:That pump motor on the resivoir would make my lights go out for a week."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Some serious stuff!!!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:i have 3 phase power lucky my welder is 3 phase power to
Reply:Very nice - But probably, @2000psi  x  piston area =  maybe 10 - 15 tons.Still plenty of power to send stuff flying, so okay, where's the "Chicken-Man" remote control? "Here, put down that broom and hold this lever for me."  Last edited by denrep; 06-22-2009 at 11:51 PM.
Reply:Originally Posted by denrepVery nice - But probably, @2000psi  x  piston area =  maybe 10 - 15 tons.Still plenty of power to send stuff flying, so okay, where's the "Chicken-Man" remote control? "Here, put down that broom and hold this lever for me."
Reply:my mistake 2200 psi
Reply:I wonder if there are formulas to making a frame to handle a certain tonnage?  I'm sure there is.  My luck, I would build one and it would break the frame before pressing in the part.How fast is that piston travel?  Is the speed adjustable?  I have 16 brackets to make and I would like to just do it with a die and a press, but not if it's going to take forever!
Reply:the pump puts out 3000 psi at 15 gpm so the speed of the ram is control by the cross valve i have some dies that i made i will take a pic and post them here in the next day or 2
Reply:Measure the diameter of the piston as it leaves the cylinder.The area in square inches is [Dia X Dia] X 3.14 divided by 4Take that number and multiply it by the pressure, 2,200 psi or whatever you’re working with and that will the force applied by the ram.
Reply:Originally Posted by JC'sWeldingI wonder if there are formulas to making a frame to handle a certain tonnage?  I'm sure there is.  My luck, I would build one and it would break the frame before pressing in the part.How fast is that piston travel?  Is the speed adjustable?  I have 16 brackets to make and I would like to just do it with a die and a press, but not if it's going to take forever!
Reply:How bout 3.14 x (radius x radius).
Reply:Originally Posted by BoostinjdmHow bout 3.14 x (radius x radius).
Reply:the ram is 2.00 the cylinder is 5.00 id the hyd psi is 2200 is where i run it the pump will go to 3000 psi
Reply:19.635 sq inches x 2200 psi/2000or19.635x1.1=21.5985 tonsinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:JCs welding here is one of the dies i have made for it Attached Images
Reply:more 2 Attached Images
Reply:pic #3 Attached Images
Reply:pic#4 Attached Images
Reply:Now do that with 1/4 x 6  Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:i dont think my die would hold up
Reply:I'm just jealous.  That press is certainly a more ambitious project than my little Orange Crush pictured here.  Probably more well engineered, too.  I used that to bend all sorts of parts that needed bending, including 1/8 plate to make a loader bucket extensions.  Some other items were 1/4" flats up to almost 4" wide!Somewhere I have a picture of it after exceeding the strength of the top cross-bar.  The 1.5 x 2.5 x 1/4 tube got bowed up in the middle.  Trying to straighten it without a form crunched it from above and made the sides bow out.  I keep promising myself I will cut a new top crossbar from something stronger.   I also keep promising myself I will build something more along the size of what you have there.  Promises, promises.  Always promises.  Congratulations on the successful project!  Looks like it is a real performer!  -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Can you give me some more examples of what you would use a press this powerful for? My welding interests are car oriented and I'm having a difficult time thinking of applications.
Reply:thats a monster. i like it. been thinkin about doing one with an air/hydraulic jack, unless i could find a hydraulic unit for a very reasonable price
Reply:Originally Posted by aslippypic#4
GMT+8, 2025-12-23 15:06 , Processed in 0.094395 second(s), 18 queries .
