Brazing Aluminized Steel
发表于 2021-9-1 00:07:56 | 显示全部楼层 |阅读模式
I came across some aluminized steel pipes and was wondering if it's possible to braze them to, say, regular aluminum pipes.  The aluminized steel has a aluminum coating which apparently needs to be ground off before welding, so I'm thinking it would be possible given the right brazing rod (like silver solder?? ).
Reply:Here we go again.   Cronatron offers a couple types of wire that allow soldering/brazing aluminum to steel.In thin sections such as tubing wall, and subject to vibration, IMHO, it will crack in your application (I'm assuming it's either intake or exhaust for automotive).Still working on a way to do this but I'm also starting to give up. The more I learn about it the more I realize that people who know way more than I ever will have tried to come up with a suitable method and/or tried to make a suitable filler alloy and pretty much failed miserably.   It does seem to be getting closer though so maybe soon enough someone will figure it out.How about weld an aluminum flange on the aluminum and a steel flange on the (cleaned of al cladding) steel and bolt it up tight.  Bingo, a strong steel to aluminum joint. Last edited by phila.renewal; 08-13-2007 at 11:06 AM.Favorite right now is a Miller Syncro 200.Tons of tools and I blame at least one of them when things don't go right.
Reply:Or just weld it? I've welded aluminized steel before and I don't recall ever grinding off the aluminum to weld it? maybe I'm missing something here?
Reply:Originally Posted by mpowerOr just weld it? I've welded aluminized steel before and I don't recall ever grinding off the aluminum to weld it? maybe I'm missing something here?
Reply:Originally Posted by ZTFabYou've welded aluminized steel tubing to aluminum tubing?Got any pics?- Paul
Reply:mpower - he's asking if you can weld Aluminized Mild Steel tubing to Aluminum tubing...not Aluminized to aluminized. Paul and Zap - I think he didn't read the entire question. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZonePaul and Zap - I think he didn't read the entire question.
Reply:It has been rather slow in here today... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Ah - you guys are ball busterzzzz! On a side note, if you're bored, I'm in the chat...all alone.  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:=) i read it completely alright, I must have left out some parts that I didn't want to read because I was so eager to reply- bored at work syndrome lol.
GMT+8, 2025-12-23 15:01 , Processed in 0.091153 second(s), 18 queries .
