propane torch
发表于 2021-9-1 00:07:44 | 显示全部楼层 |阅读模式
I have one of those gazillion BTU torches, but heats too large an area. And when I turn pressure down it blows soot. This one burns clean from 5 to 15 psi, wants to blow out past 15. Stainless scrap, tig brazed brass stock in end of 3/4 tube and turned weld down. drilled and tapped for .035 mig tip. 1.25  tube with 1.5 flame holder.Peter Attached Images
Reply:more pics Attached Images
Reply:Awesome build.  Do you have to ignite it yourself?It's not what you can buy, it's what you can build.
Reply:Originally Posted by JC'sWeldingAwesome build.  Do you have to ignite it yourself?
Reply:Looks good, Like I know what I'm lookin' atWouldn't know the first thing about how to carb the thing.  Orifices, distances, diameters, you name itNice to be able to these things  And make it look GOOD"Any day above ground is a good day"http://www.farmersamm.com/
Reply:THATS SWEET....I two have build a two burner for my homemade forge as well. Still working on it.all most done. Will post pics if you like.I like your torch better.I to used a MIG .035 tip for mine as well. Red.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:Originally Posted by Big Red One.THATS SWEET....I two have build a two burner for my homemade forge as well. Still working on it.all most done. Will post pics if you like.I like your torch better.I to used a MIG .035 tip for mine as well. Red.
Reply:How does it perform with larger and smaller Mig tips?
Reply:Did you experiment with how far to position the MIG tip orifice inside the shroud?  Seems to work great, but I'd figure to get the right draft you'd have to have the tip just the right distance inside the shroud?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Originally Posted by castweldIgnite with striker.If I knew where to get spark ignition components, I would consider installing.ThanksPeter
Reply:cast weld u can get the igniter magnetic mechanic is talking about u can get them from home depot lowes and i think ace hardware it is a replacement igniter for a grill u will probally have to fab up a bracket to put in the push button they are only like 15 or 20 dollars u can also use them for a spud gun take it easy and good work man i may have to build one for doing work around the farm and  house later agwelderold skool idealarc welderEsab multi tool Milwauake 7inch angle grinder the best of all tho the oxyacceteline set up
Reply:Originally Posted by DSWI'd like to see the picts. Thats one project I've wanted to do for quite a while. I've looked at several home made and purchased burners and am curious what you chose to do.castweld: Very nice work. I might have to look into building something like that for my lead pot.
Reply:Thanks for the picts of the forge. I'm saving the link and picts and I'll let you know if I get the time to try and put one together.I take it the swivel plates allow you to adjust the air flow and the tips are inside. Propane or natural gas? What sort of reg do you use and how many psi?
Reply:Originally Posted by farmersammLooks good, Like I know what I'm lookin' atWouldn't know the first thing about how to carb the thing.  Orifices, distances, diameters, you name itNice to be able to these things  And make it look GOOD
GMT+8, 2025-12-23 15:03 , Processed in 0.067898 second(s), 19 queries .
