Melting pot
发表于 2021-9-1 00:07:43 | 显示全部楼层 |阅读模式
Made a little quart sized melting pot up. Thought it kind a went together nice, it was as much welding practice as making something I needed.I'm almost thinking my welding is starting to suck a little less, but see something that don't look right let me know. Well other than the tack welds to put the end cap on a shaft to mount it in the lathe, they were just temporaray zaps with the mig. Attached ImagesLincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
Reply:Nice. I was looking at one the other day at an auction. Similar to yours but the guy took a piece of angle iron and cut it in to make a spout. I'm going to do that to mine. Basicly took the angle iron and drew a line from the outside tips of the legs to the corner of the angle, then marked the pot to match and cut and welded.
Reply:Never thought of that, bet it would work nice for pouring.Lincoln PT185 TIGLincoln 175 MIGLincoln 240 amp AC StickLind Needle Arc plasma welderPlasma cutter, soon???
GMT+8, 2025-12-23 14:49 , Processed in 0.098628 second(s), 18 queries .
