Puddle Control
发表于 2021-9-1 00:07:38 | 显示全部楼层 |阅读模式
Ok, I am going to attempt some more TIG this weekend.My question is, last weekend I got the puddle started and put enough heat into the joint to keep the puddle moving constantly kind of like GMAW and FCAW but a little slower.  Now, what is the correct way?  Should I use less heat to build the puddle, add filler, move, wait for puddle add filler, move etc. or do I keep doing what I was doing before?I have a chart from Lincoln that indicates travel speed in inches per minute, so I think I may have been trying to move to fast by adding more heat.Thanks in advance.Build a Barstool Racer at BarFlyRacers.com!
Reply:Now that you are this far, all you can do is try all this stuff and find what works best for you and your welding style.Some like it hot, some like it perefectly even..........Try it all.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-23 15:07 , Processed in 0.093843 second(s), 18 queries .
