查看: 13|回复: 0
How to choose precise spot welder? How much is a precise spot welder?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:47:53 | 显示全部楼层 |阅读模式
图文
图文封面:
Generally, when many buyers or bosses choose welding equipment, the question they often ask is the price. How much is a precision spot welder? Pudian Xiaobian tells you that different brands have different power prices. The higher the power is, the higher the price will be. The smaller the power is, the cheaper it will be. Buy Welding equipment is used for manufacturing, so can not only consider the price factor, the performance and quality of the machine and after-sales service these are the factors that need to be considered, choose the welding equipment suitable for their own products is very important. In the purchase of precision spot welding machine, the general electric small series suggest you can consider these aspects.
1. First of all, welding materials should be considered
Precision spot welding machine can weld a wide range of materials. Copper, iron, aluminum, carbon steel, stainless steel, galvanized sheet, aluminum alloy and other metal materials can be welded. If the two welding materials are copper and copper with good conductivity and low resistance, in order to heat quickly in a short time, it is necessary to choose a welding equipment with concentrated energy, Generally, we recommend the use of precision spot welding machine. Because the ordinary power frequency AC power supply is unable to meet the needs of welding, because the AC has the effect of zero crossing, the energy is zero at zero crossing. So we should choose precise spot welding machine, input current is DC, current flat welding, inductive reactance is zero, 100Hz working frequency, time control, static stiffness 1ms, high quality, high efficiency welding ability, power factor up to 98%, three-phase input load balance, greatly reduce the impact on the user grid. And just good, also can prevent electrode head, safety, energy saving, flexible configuration, so if you have requirements for the quality of welding machine, you must choose precision spot welding machine.
2. Secondly, maintenance costs should also be taken into account
General spot welding machine after long-term work use, mechanical equipment wear resistance will have attenuation, loss will become larger. So the best choice is precision spot welding machine, they have high control precision, time control precision 1ms, power factor as high as 98%, smooth current, high quality and high efficiency welding ability, reduce the impact on the user grid, save energy and cost, improve efficiency. Precision spot welding machine is suitable for welding of electrical switches, copper wire joints, terminal wires, coils, fuses and hardware. It is widely used for welding of precision components such as electronic appliances, medical devices and instruments
3、The most important after-sales service must be considered
Most of the purchase or manufacturers purchase welding equipment, always focus on the price of welding equipment, but ignore the spot welding equipment manufacturers' after-sales service ability and other professional guidance and training problems. Because welding equipment spot welder is a long-term use of equipment, no matter how advanced welding equipment, there will always be a day of failure. If there is no professional maintenance personnel, it is very difficult to carry out maintenance when there is a problem, so buyers or owners must ask the seller about the pre-sale, in sale and after-sales service when choosing the equipment.
The precision spot welding machine developed by Pudian does not need to add any welding materials, so it has high efficiency and low cost. It is convenient for automation and so on. The medium frequency inverter spot welding machine adopts imported high-performance pneumatic components, the main shaft and the guide shaft are chrome plated smooth circle, the pressure transmitted is flexible and reliable, and there is no virtual position. The water-saving circulating water-cooling system is equipped with water-cooling connector, which is convenient for water-cooling, with accurate and stable current and excellent performance. Results the design is optimized, beautiful, energy saving, high efficiency, strong power output, good stability and long service life.
The controller current of spot welding machine is closed-loop control, which can control the actual welding current with high speed and precision. It has the functions of welding pressure time, welding time length, delay, stop, welding current and other parameters, temperature control and monitoring. It can meet the welding function requirements of different products, and can realize multi-purpose of one machine and welding of various materials. It can weld copper, aluminum, iron, carbon steel, galvanized sheet and other precision instruments, electronic components, etc.
Guangdong Pudian Automation Technology Co., Ltd. is a professional manufacturer of welding equipment. For 16 years, it has focused on R & D and sales of spot welding machine, laser welding machine, non-standard automatic welding machine, welding robot and other welding equipment. Pudian welding machine focuses on the field of metal welding, saving energy and reducing consumption, improving welding quality and improving welding efficiency, Reducing the cost of welding is our fundamental service to customers.
Free proofing hotline: +86-13553885280
Address: Zone B, 1st floor, C-1, No. 6, industrial North Road, industrial park, Songshan Lake high tech Industrial Development Zone, Dongguan, Guangdong Province, Tel: +86-769-81767569
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-17 04:10 , Processed in 0.103981 second(s), 21 queries .
