Installing Tweco cable ends
发表于 2021-9-1 00:07:31 | 显示全部楼层 |阅读模式
I thought in the past the Tweco style couplers came with a piece of brass of copper shim stock that was wrapped around the wire before clamping in the lug.  I always thought this was a good idea and worked well.  I have found cable ends that have been hot and you can not get them apart to make another connection.  I have a few that I have put never seize on the clamp screw and have put dielectric grease on others.  I guess most just strip the cable back and clamp it down with no thought of how it will be a few years down the road.  I know the goal is to make a good connection with as little resistance as possible to avoid current loss and heat generation.I am just asking around to see how others are installing their cable ends.Dan
Reply:Originally Posted by DanD78 . . .I am just asking around to see how others are installing their cable ends.
Reply:i  take a piece of 1/2" L copper, cut me out a  180 degree piece and steel wool both sides..crimp and mash as required..i recently bought a 200amp stinger for stick welding..$10 in harbor freight that came with a little piece of metal to be so used..saw the identical one in tractor supply  for $15 next day..
Reply:Recently, I made up two sets of welding leads from a single 100 ft long lead with end terminated with a Dinse connector.  As you say, the set screw was just mashed down on the wires - no brass/copper protector plate.  Made it harder to get the connector/cable apart.When installing ground clamps and electrode holders, I used either the brass shim that came with half the clamps/holders or I made my own sleeve from brass shim stock - a bonus is that the thin brass wrap holds all the loose wires together for insertion into the clamp/holder.Another good idea on rubber covered connectors is to put a film grease on the inside of the rubber.  I spent darn near 1/2 hour trying to pry the rubber sleeve off the brass inset - yes I had removed the set screw!  A film of lubricant would have eased my pain. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Ive "tinned" cable ends in the past, just solder em up so the end is more or less solid and clamp that down, Seems to keep the cable from fraying and loosing strands and the lug has something more solid to bite into. Also helps get large cable into a hole that is nearly too small
Reply:Originally Posted by ironmangqIve "tinned" cable ends in the past, just solder em up so the end is more or less solid and clamp that down, Seems to keep the cable from fraying and loosing strands and the lug has something more solid to bite into. Also helps get large cable into a hole that is nearly too small
Reply:Just an FYI, you can get solder from an electronics store that still has lead in it.  A bit softer and melts at something like 700deg F vs. 800deg F for the no-lead (I know it about 100 deg diff).Its getting harder to find because Europe doesn't even want electronics with lead (disposal issues).  Pretty sure its still legal in the US.Just don't mix it up with your plumbing solder.(duh!)Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:eutectic solder, 63% tin 37% lead has the lowest melting point and is used in making printed circuit board repairs.  It also has a very narrow (almost non existent) plastic range. As I recall it is either solid or liqud.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:A film of lubricant would have eased my pain.
Reply:I've cut shim sections out of a coke can to get me out of trouble in the field. a squirt of anti-spatter spray or a film of nozzle dip will ease the pain also..... another trick for tweco handpieces is to silver solder the loose copper thingy and the cable inside the connector block on the side away from the grub screws so you can change goosenecks without the whole thing coming apart. i can change different angled goosenecks in 2 minutes. Handy for bucket work.
Reply:Originally Posted by farmallthat's what she said.
GMT+8, 2025-12-23 14:49 , Processed in 0.097564 second(s), 18 queries .
