Is this right?
发表于 2021-9-1 00:07:31 | 显示全部楼层 |阅读模式
I just bought a weldcraft wp-18 tig torch and chose to use a gas lens instead of a collet body anyhow I bought parts 3,4,5 and 6 as shown in the pics but to me it doesn't look right after put together?  Attached Images
Reply:Bottom picture is right."The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:It just looks retarded to me that the insulator that's on the torch body is tapered and the gas lens insulator goes straight across I originally thought that the gas lens insulator was supposed to take the place of the tapered insulator, it just looks sloppy to me i don't know why they couldn't just redesign the gas lens insulator to be used independently with the torch body.
Reply:based on the picture I would say the configuration goes 6,5,4,10,1,3 which it looks like is your second picture.if you follow the pattern, it appears that the parts aline  on the angle. 9,8,7,10,1, - 13,12,11,10,1 - 14,12,11,10,1 - Ect.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I had a similar issue with my lens on. Wp17.  Does the insulator flip the other way?  If not, I agree with pic 2.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Ya, I understand from the diagram that the parts align at a angle but if don't include part 10 you can see how it looks in picture 1, and unfortunately the insulator doesn't flip the other way i had all ready tried.
Reply:Does anybody have any ideas here?  Attached Images
Reply:Is there something im missing there has to be a correct insulator anybody know the correct part number i would need?
GMT+8, 2025-12-23 14:49 , Processed in 0.095485 second(s), 18 queries .
