Extra port on Regulator?
发表于 2021-9-1 00:07:30 | 显示全部楼层 |阅读模式
There is an extra port on my regulator that is marked LP. I'm assuming low pressure?Can I just put a fitting in there and a shut off valve and use that for back purging when I need to? Something that can be found at home depot?I have some SS I want to practice on.Also is there an inexpensive hose I can use as well?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Yes, that means low pressure. Look for Tygon tubing. It's a clear, flexible tubing. Paraflex will also work. The latter is what I used a lot of in my former job for hooking up purge bottles and helium leak check bottles.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
GMT+8, 2025-12-23 14:48 , Processed in 0.064750 second(s), 18 queries .
