how much is a Miller Syncrowave 250 worth?
发表于 2021-9-1 00:07:25 | 显示全部楼层 |阅读模式
How much is a 15 year old Miller 250 Syncrowave 250 worth?  It is in nice condition and has relatively low hours for it's age.  I'm considering buying it instead of the the 4 in one Super160 China no name units (longevity, Riland, Everlast, etc) I was considering.  I am still a little scared about if something happens to it and I end up having nobody that can diagnose it.Thanks,  Appreciate the help.Adam
Reply:Originally Posted by adamb113How much is a 15 year old Miller 250 Syncrowave 250 worth?  It is in nice condition and has relatively low hours for it's age.  I'm considering buying it instead of the the 4 in one Super160 China no name units (longevity, Riland, Everlast, etc) I was considering.  I am still a little scared about if something happens to it and I end up having nobody that can diagnose it.Thanks,  Appreciate the help.Adam
Reply:I don't think there is too much to worry about.  The SW250 is a reliable tig welder.   There are places to buy parts for it.    Weldersales would be a good source for any parts.  You can PM him for any questions.  He knows his stuff.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:8 - 12 months ago they were going between 2400 - 2900 on ebay, everything but bottles. Haven't been watching since then.Anything worth doing is worth doing RIGHT
Reply:I just took it home for $1000 with a bottle.  It has alot of nice features.  The guy I bought it from is a professional welder.  He will come over to help me to set it up and get some basic instruction under my belt.  That alone is priceless.  I'm very excited!  I think I got a deal!
Reply:Does this mean you've made up your mind then? City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by adamb113I just took it home for $1000 with a bottle.  It has alot of nice features.  The guy I bought it from is a professional welder.  He will come over to help me to set it up and get some basic instruction under my belt.  That alone is priceless.  I'm very excited!  I think I got a deal!
Reply:Sorry for the delay.  Here is a pic of the panel and a list of what the knobs say...Pre-flowSpotCraterPos FlowHigh Freq startArc ControlAC balanceSo do I have Pulse and DIG? Attached Images
Reply:AHHH MANNN...I wish I had that and you had a feather...aww nevermindNo pulse, but who cares...that thing looks like it ain't been out of the box long !!Anything worth doing is worth doing RIGHT
Reply:What is pulse and DIG
Reply:Tech experts should be along shortly...your arc control should function as a type of dig. Can't explain pulse but in applications where I've had to use it it was for better penetration. I'd rather control that myself with spray.Anything worth doing is worth doing RIGHT
Reply:There is a good explanation on the DIG in this thread:http://www.weldingweb.com/vbb/showthread...=mig+stainlessWorth reading.MichaelMillermatic 25115" Rockwell Drill Press10" Logan Lathe5hp - 2-stage 80 Gallon CompressorHome Made Sand / Soda Blaster
Reply:As I understand it, Dig provides additonal short circuit amperage at low voltages to prevent the electrode from sticking to the work.According to my 2006 Synchrowave 200 Manual, Dig Control is initiated when Stick is selected. Percentages of Dig vary from 0 to 100%. When set at zero, the Dig current will provide no additional short-circuit amperage at low arc voltage. This would be similar to a standard stick machine with no Dig. Increasing the Dig percentage increases the short-circuit amperage at low arc voltages to help start and maintain an arc and prevent the electrode from sticking to the workpiece. The manual shows suggested settings for different rods. For example: For cellulose electrodes (6010, 6011) use a Dig setting of 50 to 80%.For Low hydrogen electrodes such as 7018, they recommend 25 to 35%.For other electrodes, they suggest using enough percentage to keep electrodes from stickng. --------------------As to pulse, well, it's just pulse.  My manual says that it switches the weld output between a high peak amperage and a low or background amperage at a controlled rate of pulses per second. This lowers the average welding amperage which can reduce heat input and improve weld puddle control. 1 to 2 pulses per second, for example, can improve the timing and amount of filler metal that are added to the weld puddle. Filler metal can be added to the weld puddle when the pulse output is on the high side of the cycle. Fast pulsing rates, according to the book, can be very helpful when welding without filler metal. As of now, I've only struck a few arcs on TIG with my air-cooled torch but I haven't tried pulse or Stick DIG yet. I'm still waiting on delivery of my new pump motor for refurbishing my vintage cooling circulator. The picture of that welder shows that it's in very good condition. It's got square wave balance and arc control so it will probably be pretty versatile. Hope you enjoy it!  Last edited by gnm109; 09-07-2007 at 10:29 PM.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:You got yourself a very nice unit.. It has the optional amperage and voltage gauges as well as the pre-flow and spot timer.Millermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:Thanks Guys!  So am I in the club now? I hope so becasue I already got the "Born to weld tatoo".
GMT+8, 2025-12-23 14:48 , Processed in 0.103186 second(s), 18 queries .
