BDSM parts rack
发表于 2021-9-1 00:07:21 | 显示全部楼层 |阅读模式
Made this for local machine shop. Holds 600 small parts isolated form contact contamination moving from station to station. Attached ImagesMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Looks like something out of the Hellraiser movies ......
Reply:Good job on that, everything looks straight and square. Must have been a bit of a pain fitting her all up and keeping everything aligned just right. RegardsER70s-2P.s. I don't think those safety shoes would pass up here North of the border
Reply:Looks like a post-appocalyptic christmas tree.
Reply:what process did you use to stick them little buggers on ?nice job on the straight ....
Reply:Actually, those look like weld-on studs from an auto panel puller .......
Reply:It looks like roundbar mig welded on.  Looks good!
Reply:That looks like a positive PITA to make.  It sure came out nice thoughI like the air conditioner positioner/dolly/jack/whatever.  That's super cool.  Full use of the door, storage in off season, no backaches"Any day above ground is a good day"http://www.farmersamm.com/
Reply:That swuare tube with V welded on either end is genius. That turned out great.
Reply:The welding looks great, but I think you should fire the photographer!  He's almost bad as I am!
Reply:Originally Posted by SpyGuyLooks like something out of the Hellraiser movies ......
Reply:Originally Posted by ER70s-2Good job on that, everything looks straight and square. Must have been a bit of a pain fitting her all up and keeping everything aligned just right. RegardsER70s-2P.s. I don't think those safety shoes would pass up here North of the border
Reply:Originally Posted by weldbeadwhat process did you use to stick them little buggers on ?nice job on the straight ....
Reply:Originally Posted by SpyGuyActually, those look like weld-on studs from an auto panel puller .......
Reply:Originally Posted by farmersammThat looks like a positive PITA to make.  It sure came out nice thoughI like the air conditioner positioner/dolly/jack/whatever.  That's super cool.  Full use of the door, storage in off season, no backaches
Reply:Originally Posted by Oldiron2The welding looks great, but I think you should fire the photographer!  He's almost bad as I am!
Reply:Great job.  But as Samm said, it would be a real PITA, especially with the little dots on the bars.
Reply:Nice work on the mid evil  juggernaut war club!I have one of those roller stands that look just like the one in picture 3,  broke that thing on the first use, I guess it wasn't meant to hold up a 4 1/2"x1/2"x 20' piece of flat steel. I still use it, just had to make some modifications to it is all!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisNice work on the mid evil  juggernaut war club!I have one of those roller stands that look just like the one in picture 3,  broke that thing on the first use, I guess it wasn't meant to hold up a 4 1/2"x1/2"x 20' piece of flat steel. I still use it, just had to make some modifications to it is all!
Reply:ummmmmmmmmmm..........     BDSM????   Apparently this acronym means something other than kinky sex stuff to machine shop guys.http://en.wikipedia.org/wiki/BDSMLincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Originally Posted by Aquafireummmmmmmmmmm..........     BDSM????   Apparently this acronym means something other than kinky sex stuff to machine shop guys.http://en.wikipedia.org/wiki/BDSM
Reply:Well, have y'all considered that he may have called it that for that exact reason?  I mean, looks kinda like a masochist's stripper pole or something, so ........
Reply:So, am I the ONLY one who had a completely different idea of what this project was before I opened the thread?http://en.wikipedia.org/wiki/BDSM (Had some kinky girlfriends) (It appears I'm too late)Last edited by Joe Smith; 07-09-2009 at 08:34 PM.
Reply:Y'all just have some dirty minds, dirty kinky minds ............. not like that's a bad thing, of course .....
Reply:to the guys that seem to be dwelling on the BDSM, sorry, no code names. I labeled it simply on visual impression. But I'm sure there are places y'all can further explore the fetish thing. Only welding and fabing here.  Oh yeah, I did come up with a cool trick to insure no part contamination, rust..etc, from contact with pegs. I used 3/8" heat shrink. Worked great and just today, the customer ordered 4 more racks.Last edited by wagin; 07-12-2009 at 02:52 AM.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180With 4 more racks at 120 some pegs each, I'd look at posibly getting someone to turn the pegs instead of welding little dots.My guess would be that this should be super easy for someone with a cnc lathe. Start with the rods oversized and then cut out the areas in between slightly if just notches  instead of bumps to seperate the parts wouldn't work.I forget where I saw it, but I saw a demo on what I believe was a cnc turret lathe, doing brass lever handles. Auto feed on the stock. machine came in did all the cuts to shape, then severed the piece, advanced the stock and repeated.You might also think about  getting some flat stock and drilling holes on the centers you want. If you machine a step at the rear of the pins when they are turned, you could insert them in the holes and back weld them in. A quick jig could be made to simplify this. Have a series of tubes that you load the pins in, then drop the flat over and back weld all the pins.
Reply:I applaud your diligence and persistence with such a project... Great job, and great job selling more!Hobart 125Words mean things
Reply:Originally Posted by DSWWith 4 more racks at 120 some pegs each, I'd look at possibly getting someone to turn the pegs instead of welding little dots.My guess would be that this should be super easy for someone with a cnc lathe. Start with the rods oversized and then cut out the areas in between slightly if just notches  instead of bumps to seperate the parts wouldn't work.I forget where I saw it, but I saw a demo on what I believe was a cnc turret lathe, doing brass lever handles. Auto feed on the stock. machine came in did all the cuts to shape, then severed the piece, advanced the stock and repeated.You might also think about  getting some flat stock and drilling holes on the centers you want. If you machine a step at the rear of the pins when they are turned, you could insert them in the holes and back weld them in. A quick jig could be made to simplify this. Have a series of tubes that you load the pins in, then drop the flat over and back weld all the pins.
GMT+8, 2025-12-23 14:50 , Processed in 0.102182 second(s), 18 queries .
