A step
发表于 2021-9-1 00:07:19 | 显示全部楼层 |阅读模式
I did this for a local armed guard company.  Really all I did was cut off the prior step surface and attach the 1' x 4' piece of laser cut diamond plate that I got from a local steel supplier.  The problem with the prior step was that whomever originally built the stair used two layers of expanded metal as the surface.  To no surprise, it broke. Here are the pictures.  The first picture shows all the caked on dirt and shmutz that built up over the years that I had the pleasure of grinding/cutting through while removing the expanded metal. All cleaned up!  I stitch welded it with self shielded wire using my little lincoln mig pack 10 welder, which worked great.  We didn't want to unbolt the stair because it was bolted into the concrete and bricks.  Thanks for looking!
Reply:both pics are the same..
Reply:Originally Posted by roadkillbobbboth pics are the same..
Reply:both pics are the same.. Read the last paragraph that he typed on the post, you will realize what makes the pictures different!Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Originally Posted by sidthssboth pics are the same.. Read the last paragraph that he typed on the post, you will realize what makes the pictures different!
Reply:No problem, I had to stare at the 2 pictures for a minute myself before i realized itMiller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Thats one of those wheres waldo picture sets! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:I would say more like "Find the difference"  I suppose I could have gotten away with one picture though, lol. Wait, I know!  It's making up for the lack of a "before" picture.
Reply:A step in the right direction Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Just don't stair at it to long!
GMT+8, 2025-12-23 14:49 , Processed in 0.089676 second(s), 18 queries .
