Old Backhoe repair
发表于 2021-9-1 00:07:18 | 显示全部楼层 |阅读模式
I spent 2 1/2 hrs figuring out how to scan and fit pictures to this forum. I do a lot of typing but I haven't showed much work. So here is a start. I posted these pics on a different thread, but it was a dead thread and I didn't feel like wasting that time on a dead thread.The job required my Victor torch, 7 1/2" grinder, tape, level,  and a welder. The rod was all 7018, mostly 1/8 but I am sure there was some 3/32 thrown in. Obviously the bushings were sloppy to begin with. But I still pulled a tape from the stick to bucket bushing to assure as square of a repair as possible. I use the level to verify that both sets of of bushings are on the same level plane. (stick to boom and stick to bucket) This gives me the best possible alignment for a field repair. I found that a 9" torpedo level can be your best friend in the field sometimes.Duane / Ken, I know you saw these all ready, but 5 views for 2.5 hrs of effort seemed like a waste.Finish to follow. Attached ImagesLincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:Finished repair. Scab plates are 3/8 I think, from the caca steel on board the truck. Attached ImagesLincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:Looks like a nice clean repair.What did you use for the replacement bushing material?Was the repair a result of a failure, or to prevent a pending failure?
Reply:Originally Posted by Big_EddyLooks like a nice clean repair.What did you use for the replacement bushing material?Was the repair a result of a failure, or to prevent a pending failure?
Reply:Ain't no shame in resurrecting an old thread, 'specially if it's your own.Admittedly, I'm still not up to anything resembling a "professional" level with my welding, but I do recognize nice work when I see it.  Re-enforcement is never a bad thing, especially on something this hard-used.
Reply:Wow, ripped the end right off of  the stick!That is a lot of bucket for a smaller machine.Nice rebuild, Thanks for putting the effort into posting it.Tell the truth - Did you ever hit your shin on your rig's trailer hitch?    Good luck
Reply:Originally Posted by denrepWow, ripped the end right off of  the stick!That is a lot of bucket for a smaller machine.Nice rebuild, Thanks for putting the effort into posting it.Tell the truth - Did you ever hit your shin on your rig's trailer hitch?    Good luck
Reply:I have a hard time with out of position welds.I think your work looks fine!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammI have a hard time with out of position welds.I think your work looks fine!!
Reply:Great fix gclamp.  Would have loved to have seen the operators' face when it broke off.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-23 14:49 , Processed in 0.112058 second(s), 18 queries .
