Longevity stickweld 140 stl - 140 amp stick - tig welder setup and review
发表于 2021-8-31 16:58:55 | 显示全部楼层 |阅读模式
Hey Everyone Check out this new video on our Longevity Stickweld 140 STL.Portable, Versatile and PortableThe LONGEVITY StickWeld 140 STL is an excellent portable,yet powerful stick welder that is capable of welding on both 110v and 220v welding current. This featherweight stick welder weighs in at 9 LBS and ranges in amperage from 30-140 when connected to a 220v outlet.LongevityLONGEVITYPhone: 877-566-4462
Reply:Originally Posted by longevity-inc.comThis featherweight stick welder weighs in at 9 LBS and ranges in amperage from 30-140 when connected to a 220v outlet.
Reply:Originally Posted by geezerbillWhat is the amperage range when plugged into a 20 amp 110 outlet?
Reply:That's incredible....and the duty cycle at 140 and say, 100 amps?( on 110)Last edited by geezerbill; 02-19-2015 at 07:26 PM.Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:I don't really need the answer to the above, as I have decided on the straight Stickweld 140. I don't have a need for the Lift Start at this time.ThanksLast edited by geezerbill; 02-20-2015 at 03:40 PM.Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:The STL is no longer in production.
GMT+8, 2025-12-19 00:40 , Processed in 0.100184 second(s), 18 queries .
