stainless filler question
发表于 2021-9-1 00:07:12 | 显示全部楼层 |阅读模式
does stainless filler, during the tig process,  "fill" in porosity? I have read it some where and was woundering if it was true to some extent, or completely false. I asked my welding instructor if he ever heard anything like that and he said no. So i'm just curious if this is true of not.
Reply:The search feature is your friend . . . this is a current thread.http://weldingweb.com/vbb/showthread.php?t=61159Dynasty 300DXSmith He/Ar gas mixerMM350PHobart Handler 120Smith LW7, MW5, AW1A
Reply:Hey jpmiller,I still make attempts to understand those who ask about porosity & what "cures", such as the thread indicated, will work. The ONLY cure is to grind out the porosity & re-weld. Porosity is a sign that one parameter of the welding process used is incorrect & that parameter must be identified & corrected.......quite simple, isn't it? There are many variables that cause porosity & generally it is operator error. You cannot "fix" a problem by adding more to the problem.....just doesn't work. You will find clean, dirt/rust-free, properly prepped material will weld quite nicely with no issues if you have the knowledge/experience with the process used.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Originally Posted by yorkiepapHey jpmiller,I still make attempts to understand those who ask about porosity & what "cures", such as the thread indicated, will work. The ONLY cure is to grind out the porosity & re-weld. Porosity is a sign that one parameter of the welding process used is incorrect & that parameter must be identified & corrected.......quite simple, isn't it? There are many variables that cause porosity & generally it is operator error. You cannot "fix" a problem by adding more to the problem.....just doesn't work. You will find clean, dirt/rust-free, properly prepped material will weld quite nicely with no issues if you have the knowledge/experience with the process used.Denny
GMT+8, 2025-12-23 16:33 , Processed in 0.067184 second(s), 18 queries .
