My first welds/beads...
发表于 2021-9-1 00:07:11 | 显示全部楼层 |阅读模式
Hey all, Finally got a chance to try out the MM211.  Here are some pics of my very first beads....ever!   LOL!  I really dont know why Im posting these or what I expect u all to say, I just thought I would share....These are on an old leaf spring that I cut up to make a slapper, so the thckness varies.  The pic of the beads is first on right then goes left.  The first 2 I just tried to go straight down and keep a steady hand.  The next 2 I tried some "U"'s as I went.The other pics are of 2 pieces I welded together.  I tried to push it in "U"'s.  It doesnt look like it really penetrated till the end, but thats where the steel got thinner.  I was set at 4/55 with .030 wire.I put it in the vise and beat on it with a bfg, didnt break, so I guess the penetration was okay.Anyways, like I said, just thought I would share.  Thanks! Attached Images
Reply:Uhmm, I don't think this is the first time, ever. So you chose some of the most difficult steel to weld, left it a bit crusty, and just did it? Certainly you did some school?Did you mean first ever on this machine?  Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonUhmm, I don't think this is the first time, ever. So you chose some of the most difficult steel to weld, left it a bit crusty, and just did it? Certainly you did some school?Did you mean first ever on this machine?
Reply:the difficulty is caused by the composite of the steel. Yes, get some mild steel to practice with. Clean it up first if it's rusty, shiny metal when using Mig. some times flux core can handle dirty welding area, but it's a better practice to clean the welding area prior to welding.your first 4 welds look cold. the joint looks better, but you can tell at the end you started hurrying.Practice Practice Practice.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by kllrbeeOk, even tho I get the feeling yur messing with me shove...  no, this is the first time I have ever welded anything.  I did a small amount of soldering in shop class 20 years ago, but was too busy chasing the girls around the shop to pay attention to what I was doing....lol.  No school, but I will be starting a class at the community college in Febuary.  Its your basic intro to welding class.Btw, why is the leaf springs considered some of the most difficult steel to weld?  Cuz of the different thickness?..
Reply:Looks much better than my first beads. What's a slapper? Oh and did you mean BFH? If not then what is a bfg?Lincoln Handy mig Longevity Stickweld140Hobart Handler 210
Reply:What you've done looks much better than mine....Everyday is a beautiful day.
GMT+8, 2025-12-23 16:22 , Processed in 0.091706 second(s), 18 queries .
