查看: 13|回复: 0
Problems With My Ball (phase 1)
发表于 2021-9-1 00:07:04 | 显示全部楼层 |阅读模式
The first cut is the deepestAll cuts on drivers side were made so that the slag was blown outboard of the fuel tanks.  Welding blanket was used to protect paint, tires, fuel fill hoses, and brake components.  Lottsa water tooCuts on passenger side were blown inwards.Something like this, I don't want a nice narrow cut.  I make a double width cut and make sure there's nothing but air between the cut pieces.  I don't want to have to fool around with dingleberries when I lift the bed off tomorrow.  It's just a matter of blowing more metal out of the top or bottom of the cut.I also prefer a tip capable of cutting up to 1/2".  It's too big for the stuff being cut here, but it's faster on the preheat, and the 02 stream is more efficient at blowing slag away.It was a nervous few hours.  I don't do this kind of stuff very often, and certainly not around gas tanks.  It takes extreme care to make sure the torch is pointed in a good direction at all times before, during, and after the cut.  There's a lot of stuff that can be accidentally damaged by the intense heat.  INCLUDING MENo boom, Thank God Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice precautionary measures Sam.  Keep it up, keep safe and whatever you do - keep cool.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I worked for a company demo a old Alcoa plant down here and thats how I did my cuts...amazing how much just a small amount of steel can hold,and how stuff jumps when the crane pulls it apart
Reply:Now Sam, before you go running off to town in the morning-----------------------don't forget you've cut all the hold down tabs on that bed!!
Reply:I have a feeling it will be mostly travel in the PU until this gets done"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Its nice when a plan doesn't blow up in your face! You going to give that headache rack a lift after you lower the bed?#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-23 16:34 , Processed in 0.086675 second(s), 18 queries .
