Tractor Bumper
发表于 2021-9-1 00:07:01 | 显示全部楼层 |阅读模式
So i finally got my dads old tractor up to the shop and decided to do a little upgrade to the front end.nothing fancy, its 2" 3/8" steel tubing and a piece of pipe and some some angle i had laying around. i put the expanded metal just in case.works great for knocking down tallow trees thoughI break things for a living...
Reply:pretty neat
Reply:Heavy duty!!Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:Rugged enough.Are you located in the Dayton area?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:we purchased the tractor from trinity valley tractor, in dayton. our family property is just north of liberty. spent quite a few years in that part of texas.I break things for a living...
Reply:Looks ready to charge it's way through the pucker brush and hard hack! Problem:  Now you have to paint that rusty hood to keep up the appearence! -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:That'll take out a few trees ....Mondo nailed it: since you went ahead and painted the bumper, now you have to sand down the hood and redo it, too.  After that, maybe the body ..... Cant just make one part of it look good - it's all or nothing, amigo.
Reply:reminiscent of the "Road Warrior".....i like it -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:That's the perfect protection for brush hogging in an overgrown area.  Great radiator protection.  One branch can get expensive if it pokes a hole in the radiator"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Hi Guys, I am new here. I spent some time looking over some of what you guys have done recently. Pretty cool stuff. I don't want to hijack the thread but, I saw  a homemade bumper and thought I could post a pic or two of one I had made for on my cub 184. Side view.
Reply:No hijacking here, since it appears to be on the same subject.  Looks pretty nice.  Is the tab on the front for a ball hitch?
Reply:I added that as a "just in case" piece. You could put a ball in there or just a clevis for towing etc.
Reply:Originally Posted by DieselriderI added that as a "just in case" piece. You could put a ball in there or just a clevis for towing etc.
Reply:Here's some that I make for some dealers. Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-23 16:33 , Processed in 0.098327 second(s), 18 queries .
