Hey Oldtimer- Finally Fired Her Up!!!
发表于 2021-9-1 00:07:00 | 显示全部楼层 |阅读模式
First welds with the Ranger GXT3/8 plate, 1/8 Excalibur , 135-140amps14" weld broken into 3 segmentsThe machine does beautifully with 7018, I mean like butter.  And no steenkin' duty cycles to worry aboutThe noise and fumes from the motor are a PITA though  It needs a BIGGER MUFLAHHH Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Ooooooooo, I see bigger rod in my future"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Well it's about time!!!!  I was beginning to think we'd see you doing a restoration job on it pretty soon.  You sound very pleased overall.Ball plate I take it?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice.  Cant wait to see how your bed turns out.
Reply:Also..Did you use a slight weave or are those just stringers?
Reply:I had decided you weren't ever going to use the thing.  Good lookin' welds. Now get some 5/32 and 3/16 so you can save some time. Excalibur is absolutely the best 7018 that I've used. Back in the olden times when Atom Arc was made by Chemtron in the US it was almost as good. But that was long ago.A tip for that flat weldin'. Get some Jet rod and go to town. It takes a little more oomph than 7018 for the same size rod but that's no problem for the Ranger. Faster, smoother deposit and it will stretch farther before letting go than any other mild rod.
Reply:Gee I was beginning to think maybe Sam gave up on that restoration and sold it. Sure looks like it did well ok you did well tooCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Samm, does your machine have that little 90 degree elbow on the exhaust? I threw the one on mine away and let the exhaust blow straight up. Seems to be quieter that way and the fumes don't seem to hang around.I welded a plate on a piece of pipe and drop it over the exhaust for a rainproof.Last edited by Oldtimer; 07-23-2009 at 05:51 PM.
Reply:Originally Posted by 99trxriderAlso..Did you use a slight weave or are those just stringers?
Reply:What ever you did..It sure looks nice..But I have been tolded many times that you arent supposed to do any sort of whipping motion at all with 7018 as it will cause slag entrapment.  Dont take this as criticism or like im telling you that its done wrong,  Its more of my one question I guess.  Looks really nice.
GMT+8, 2025-12-23 16:34 , Processed in 0.098297 second(s), 18 queries .
