1/8" vs 5/32 6011 rods
发表于 2021-9-1 00:06:57 | 显示全部楼层 |阅读模式
What are the amp range differences for a 5/32" 6011 rod versus that of a 1/8" rod?  I picked up some 5/32" today, and I have never run any on my stick welder.  Thanks!
Reply:You'll need to set your machine about 20 to 30 amps more for 5/32  than you would for 1/8 . it's always a trial & see for each  machine & weldor .[SIZE="5"Yardbird"
Reply:1/8" 6011 amp range is @ 65-120 DC+ & 75-130 A/C5/32" 6011 amp range is @ 90-145 DC+ & 100-155 A/CThis may vary a little up or down. But should be close.
Reply:I run my 5/32 6010/6011 at about 100-120, same as a 1/8" 7018. On the old Lincoln with no numbers left, it is 3rd gear and about 1/2 on the fine adjust.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingOn the old Lincoln with no numbers left, it is 3rd gear and about 1/2 on the fine adjust.
Reply:Originally Posted by olddad sure sounds like you know just how to tickle her to get what you want
Reply:I run  5/32 6013 around the same (120-130) tozzi on my linclonI don't think I've ever used 6011 5/32.
Reply:Infro, I need to stop by and give you a gas bottle I have. It is an old ARCO helium tank, can you use it?Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Tozzi if you come bye I'll put you to work ...LOL.I don't know if I could use it ? .. you can come buy any time it would be great to see you again and you could see my shop .
GMT+8, 2025-12-23 16:34 , Processed in 0.090214 second(s), 18 queries .
