Hf-251 Extension
发表于 2021-9-1 00:06:52 | 显示全部楼层 |阅读模式
Just to double check in the manual for the hf-251 it gives me part #122 973 for the extension that connects from the supplied 6 ft cable to the power source so just to be positive now part #242208025 is the same thing? http://www.millerwelds.com/pdf/spec_sheets/AY5-0.pdf I was told the part number was changed for some reason? http://www.weldfabulous.com/Search-B...-p8785028.html
Reply:Looks that way.  Maybe they changed to the plastic connectors on the 242208025 assembly from the metal ones on the 122973/4/5 pieces.miller4less has a little better price on it.http://miller4less.com/advanced_sear...vhleth4jc2eii4There's some 25 and 50 footers listed too but here's a smokin' deal on the 122975, 75' unit.http://www.ebay.com/itm/122975-mille...item3cbda97202MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks alot for the responce.
Reply:Originally Posted by duaneb55There's some 25 and 50 footers listed too but here's a smokin' deal on the 122975, 75' unit.http://www.ebay.com/itm/122975-mille...item3cbda97202
Reply:Originally Posted by tbone550BTW, Duane, my 122975 cord has plastic connectors, not metal ones.  So they must've switched connectors during the production run at some point.
GMT+8, 2025-12-23 16:22 , Processed in 0.178868 second(s), 18 queries .
