Hydraulic unit upgreade
发表于 2021-9-1 00:06:46 | 显示全部楼层 |阅读模式
Had a half azz Hydraulic unit on my shear, made from a wheel chair lift power unit, two  Merc Cruiser out drive cylinders,  a 12 volt battery, and a battery charger. What a PITA allways forgetting to turn the charger off, or worse yet, turning it on.I found a small hydraulic pump in the junk yard, cost about $1.50.Only thing I could find wrong with it was a bent shaft. Took an old washing machine motor and hooked it to the pump with a home made flexcoupling and mounted it all on a tank.Couldn't find a metric hyd. fitting for the pump output, so I used a 14mm x 1.5 capscrew amd machined a nut to accept a O-ring. Attached ImagesA butterfly without wings, is just an ugly bug
Reply:The unit mounted to the shear. Attached ImagesA butterfly without wings, is just an ugly bug
Reply:nice upgrade/recovery!MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:Thanks Brink.A butterfly without wings, is just an ugly bug
Reply:Now that's usin' what you got to get done what needs doin'.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I don't get it???? Is that a real small shear, or that pump just operates a clamp or something?  I wouldn't think that motor or pump would be sized correctly.  Please explain cuz I am a little confused and just spent a good chunk of change on a good sized motor and very small displacement pump for my press.
Reply:52" 16 ga sheer.  Hyd unit operates the shear.  Since the spool in the directional valve leaks badly, I have to add my 250 lbs on the pedal to cut 16 ga. so in that case it's just an assist.  Cuts every thing else with no problem.  If I close the regulator valve all the way it will stall the motor.  May have to up the hp when I find a new valve.Hey, we're working with junk here.A butterfly without wings, is just an ugly bug
GMT+8, 2025-12-23 16:33 , Processed in 0.096153 second(s), 18 queries .
