Now I Have to Build Another Stand. . .
发表于 2021-9-1 00:06:46 | 显示全部楼层 |阅读模式
. . .for this Wiedemann 12 station manual rotary turret punch press.Was aquired with some other equipment at a machinery auction and it's been sitting outside at the shop ever since it showed up a couple months ago (at least).  So Thursday I asked what we were going to do with it and was told we had no need for it because we have the hydraulic IronWorker.  I responded "Do you want it to go away?" to which I was told "Take it.".  Don't have to tell me twice so it came home in the back of 'burb last night.Smallest hole capable is 5/32"(center) as the 1/8" punch is broken.  Largest is 1" (right) and the rectangle (guess) is 1/4" wide x 1/2" long.  3/4" punch is missing although the die is there.  Material in photo is .063 steel and punched thru with little effort.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:NICE fine Duane!!I've wanted one of those for years but have never found a good enough deal on one.http://all-a-cart.comWelding Cart Kits and accessories
Reply:Thats great. How much throat do you have? I would guess you can go in as far as the center pivot.
Reply:Originally Posted by ZTFabNICE fine Duane!!I've wanted one of those for years but have never found a good enough deal on one.
Reply:Dang, as they say on another forum..........YOU SUCK!!!Great find & absolutely best price!!MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:You must be livin' right Duane. Very nice!
Reply:Originally Posted by duaneb55. . .for this Wiedemann 12 station manual rotary turret punch press.Was aquired with some other equipment at a machinery auction and it's been sitting outside at the shop ever since it showed up a couple months ago (at least).  So Thursday I asked what we were going to do with it and was told we had no need for it because we have the hydraulic IronWorker.  I responded "Do you want it to go away?" to which I was told "Take it.".  Don't have to tell me twice so it came home in the back of 'burb last night.Smallest hole capable is 5/32"(center) as the 1/8" punch is broken.  Largest is 1" (right) and the rectangle (guess) is 1/4" wide x 1/2" long.  3/4" punch is missing although the die is there.  Material in photo is .063 steel and punched thru with little effort.
Reply:With the square punches you can cut, rectangular holes.        Sincerely,             William McCormick
Reply:Thanks for all the pointers William.  Or is it 'Sit Down Pee Pee'.Certainly sounds as if you've put your prints on those handles a few times.  This one spins freely, unlocks easily and punches smooth.  The spring loaded punch guides seem to keep the punches from falling when disengaged from the ram but then the unit needs a good cleaning too.I haven't looked yet but I take it Wiedemann is still around?  It would be nice to replace the broken 1/8" and missing 3/4" punch and maybe add a couple other shapes depending on what's available.Adjustable stand?  Now I'm going to have to think about that a bit as Brink and I were looking at it tonight trying to decide how tall to make it.  Thanks for the suggestion.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:That's going to take a fairly wide base, heavy base or a bolted down base isn't it?
Reply:I don't think it'll be too bad Sandy.  It was quite stable just sitting there on the corner of the bench and I didn't have to worry about it pulling over.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55I don't think it'll be too bad Sandy.  It was quite stable just sitting there on the corner of the bench and I didn't have to worry about it pulling over.
Reply:huh! And you where saying about me?And this was for free even! Congrats Duane you lucky so and so! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Nice DuaneI get some punch and dies from Cleveland Tool and Die, they make several styles. If you need I can get more info.Peter
Reply:Thanks Peter.  I'll keep your offer in mind if my search otherwise comes up empty.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-23 16:31 , Processed in 0.069606 second(s), 18 queries .
