Corner Jig
发表于 2021-9-1 00:06:45 | 显示全部楼层 |阅读模式
I have no doubt that there are many variations of this out there amongst all of you. I use this particular item when I would like to have a rigid and fairly accurate corner fit-up or I am attaching something perpendicular to another part. You can make various sizes of these to accommodate small or large stuff. Would love to see others variations of this. Best regards, Allan Attached Imagesaevald
Reply:I'am going to put  that one ,on my todo list.thanks, daye
Reply:X2.  Thanks for the idea and photos Allan.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:very cool..how is the square stock attached to the  plate? i dont see any beads or heat signature..
Reply:Allan,  Welcome!!! I am very familiar with you from AWS and it is great to see you here. You are a valuable asset and an abundance of knowledge. You also have an awsome way of conveying information. Thank you. As for the corner jig, I like it. Very simple and easy to use.3M TA3
Reply:Here's a smaller one I did for the same use, smaller tubing and such. I can flip the guides to inside or outside. Attached Images
Reply:Then here's one I did for larger pieces. The opening is about seven inches so I can squeeze two 3 inch pieces in there. Long sections have to go on the floor and get propped up for level. I had to run out and take these pics. Attached Images
Reply:Cool - what jig did you use to square up the jigs?A butterfly without wings, is just an ugly bug
Reply:Hello weldbead, the square stock is slightly overhung on the edges and is fusion tig welded it also has some small welds on each end. Best regards, Allanaevald
Reply:Nice stuff there Sandy, thanks for sharing. Really like the switchable inside/outside jig. Best regards, Allanaevald
Reply:Originally Posted by Magnetic MechanicCool - what jig did you use to square up the jigs?
GMT+8, 2025-12-23 16:26 , Processed in 0.089588 second(s), 18 queries .
