midnight welding fix
发表于 2021-9-1 00:06:41 | 显示全部楼层 |阅读模式
top of rack tiggedbottom of rack tiggedNick hard at workthe hard working miller 180sd at worktomorrow project welding weights for the gymmore of Nicks midnight tig skillsthis is a clothing rack at work and they managed to crack the welds on it, it is galvinized steel junk with ugly week welds but it only supports shirts and pant. we ground down the welds and cracks and tigged them up.syncrowave 180 sd
Reply:You should take one of the long-sleeve shirts off that rack at work -- save your skin from the cancer-triggering UV coming off those arcs.
Reply:i knew i would get one comment about that stuff, man we got in to it and we could not find half of what we needed. i do need to get things more organized. syncrowave 180 sd
Reply:Hmmmmmmm........... I figured the shot of "Nick hard at work" would be one with you leaning back in a chair with a beer and your feet up .....Getting a nice tan from those UV rays?
Reply:nope no relaxing in a chair, this is Miami, Fl your talking about so it sucks to be out side welding. even there it was 90 plus and the mosquitoes where nasty.syncrowave 180 sd
Reply:Sounds like good ol' OK.  100 in the shade, 70% humidity, ticks, chiggers, mosquitoes, buffalo gnats, and every other crawling and slithering thing known to manGod, it's good to be home.........A little slice of heaven "Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-23 16:33 , Processed in 0.085237 second(s), 18 queries .
