Playing with the tig
发表于 2021-9-1 00:06:38 | 显示全部楼层 |阅读模式
Today I was in the goof off mode and tigged some 1/2" x 1" to 3/8" plate.Zaps stich weave.  I almost got it!Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Some vertical DOWN! and some triangle weave up.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Ha Ha Ha!!!! More practice and your there! ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looking pretty good!! How many amps are you throwing at it for the 3/8-1/2" ??And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:looking good david,no undercut,tidy pattern,your not playing every bead is practice,watch it improve. pipefitter.
Reply:Looks great! I need to practice with thicker materials myself. I rarely TIG anything over 1/8".Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:David are you "Walking the Cup" its looks good. JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by weldgaultDavid are you "Walking the Cup" its looks good. John
Reply:Nice work David!I wish my progress was as quick as yours!!!
Reply:Nobody noticed that smooth torch cut?  It's not straight, and I'm sure it wasn't intended to be...but that's a clean cut.
Reply:Plasma....  X1rider, I have been welding part time for 30 years.   I Just got a tig with foot pedal last year.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RPlasma....  X1rider, I have been welding part time for 30 years.   I Just got a tig with foot pedal last year.  David
Reply:DavidRegarding that stitch weave pattern do you basically run the bead in a zig zag?  Maybe this little diagram shows better what I'm trying to say.  Thanks.
Reply:First you need a root pass.  The stitch goes over that.  You can see the first pass in the pic.  Its more like the second one you drew, but closer together.  Zap could show you better than I could.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-23 16:34 , Processed in 0.095082 second(s), 18 queries .
