Flux Cored Wires
发表于 2021-9-1 00:06:38 | 显示全部楼层 |阅读模式
Flux Cored wires have 2 Catagories: Gas Shielded and Self Shielded and they should be call as such.  I would like to know which Flux Cored wire you like and which Polarity is best for you.  This should help us all in making our decisions.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Hobart Fabshield 21b is what I use when running innershield (self shielded).  It runs on DCEN.http://www.weldwell.co.nz/products/m...shield_21b.htmAnd Select-Arc 720 is what I use for Dual-Shield (gas-shielded).  It runs on DCEPhttp://www.select-arc.com
Reply:WB, what are the aws class for the wires you use.  Those are interesting wires - Good choise   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Read the details on those websites.
Reply:Thanks, should have pulled the web sites before, but good info., for everone.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by WelderBoyHobart Fabshield 21b is what I use when running innershield (self shielded).  It runs on DCEN.http://www.weldwell.co.nz/products/m...shield_21b.htmAnd Select-Arc 720 is what I use for Dual-Shield (gas-shielded).  It runs on DCEPhttp://www.select-arc.com
Reply:Originally Posted by cliveWeldwell make some great rods too, my preference where possible. Didn't realise they exported to the USA.
GMT+8, 2025-12-23 16:33 , Processed in 0.071617 second(s), 18 queries .
