Need help deciding Millermatic 211 MVP or bigger
发表于 2021-9-1 00:06:33 | 显示全部楼层 |阅读模式
Well, long story short, I had to sell my welding set up about 4 years ago due to a divorce.  It was nothing special, just a Lincoln (I think 170 or 175) set up with gas, but I loved that machine.  Lately, I've had the need to weld a couple of things.  I'm experince level is just a self taught weekend warrior and I'm looking to the pros to help. I'm not going to be doing anything crazy with the welder.   Right now I am looking at the Millermatic 211 MVP, just becuase of the dual voltage and I pretty sure that this MM211 would blow away my old Lincoln.  I like the fact that I can take it to my buddies house and help him weld anything and then if I need to go bigger, I can plug it into the 240 volts.   I have a couple of questions.  How nice of a bead will the MM 211 lay down.  My other question is, should I get the MM211 or increase my budget to the Hobart Ironman 230 or the MM212 or something equivlent. What more would I get with the Ironman 230 or MM212, ie, nicer bead, better gun, longer cords etc.  Any help and all inputs would much be appreciated.
Reply:It pretty much comes down to what type and thickness of material you plan on welding.  Also if you want to do Spray transfer as well as Short circuit transfer you will need a 250 amp class machine or larger.  Are you looking to buy new and what is your budget.   that helps with the recommendations.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:for what you are asking the 211 would be a great machine. i was faced with the same problem a year ago and looked into all the models you mentioned and more, but in the end i bit the bullet and got the mm252 with the 30a spool gun and never regretted it. it will do anything i asked it to without a quibble and i figure at my age that machine will outlast me. buy the most power you can afford and spend only once.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Im230= more powerMM212= about the same power but a better duty cyclebut neither of those are Dual VoltageGood bead= youEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:hobart ironman  230 or thermal arc fabricator 210tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:JBM hit the nail on the head.  You can't use amps you didnt buy.  The 252 is a light industrial machine while the 211 is a price point and feature thing for that range.  The 211 and 212 are good machines, get the 252 with a spool gun and you'll never look back or wish you had gone bigger to start with.  Just my .02, hope it helps.BobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys?  Trade?
Reply:Originally Posted by Broccoli1Im230= more powerMM212= about the same power but a better duty cyclebut neither of those are Dual VoltageGood bead= you
Reply:You're paying a premium with the 211 for 120/240 capability.  If that's not important to you, get a 240v machine.Jack OlsenMy garage website
Reply:If you're even considering used, look at the Millermatic 200.  It's 240 volt only, but it has the same output as many of the 250 amp machines, they used to advertise them differently back then.   Many say it's the best MIG Miller ever built because it was at a time where the designers were left unbridled as far as finance and built the best machine they could.   I got mine with a spool gun, running gear, a GA gun and the spot control panel for $299 on eBay.  I spent $75 on paint and the minor repairs it needed and have a great machine.Last edited by Drf255; 11-04-2011 at 06:22 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-23 16:33 , Processed in 0.070672 second(s), 19 queries .
